MorphOS Developer
                Posts: 1331 from 2003/6/16
				MorphOS currently only supports the native resolution of the Powerbook (1440x960). And snes9x originally calls an OS function to retrieve the best suitable screenmode, and this function seems to fail somehow.
Anyway, i had made a change years ago to clone the Ambient screen when using overlay + fullscreen mode, to prevent the monitor from resynchronizing. But I apparently forgot to upload it on my site. It's now done, you can find it at:
http://fabportnawak.free.fr/snes/snes9x-1.43.lha
Remember that you need to enabled fullscreen *and* overlay. Non overlay fullscreen mode will still try to use another screenmode, which is not supported.
[ Edited by Fab  20.08.2012 - 21:39 ]
