Mplayer commands?
    osco
    Posts: 680 from 2009/10/20
    FROM THE DOCS
    3.3.?Control
    MPlayer has a fully configurable, command driven, control layer which lets you control MPlayer with keyboard, mouse, joystick or remote control (using LIRC). See the man page for the complete list of keyboard controls.
    3.3.1.?Controls configuration
    MPlayer allows you bind any key/button to any MPlayer command using a simple config file. The syntax consist of a key name followed by a command. The default config file location is $HOME/.mplayer/input.conf but it can be overridden using the -input conf option (relative path are relative to $HOME/.mplayer).
    You can get a full list of supported key names by running mplayer -input keylist "and a full list of available commands by running mplayer -input cmdlist"
    This doesn't produce a list?
  • »23.01.10 - 21:57
    osco
    http://wiki.multimedia.cx/index.php?title=MPlayer_FAQ
    Google produced this site .Maybe the answer is here?
    BTW Mplayer is (Osco trembling) a bomb :) :-D
  • »23.01.10 - 22:31
    pampers
    Posts: 1071 from 2009/2/26
    Osco's blog again. Would you like to have ur own blog at osco.morphos.me :P
    MorphOS 3.x
  • »23.01.10 - 23:01
    osco
    Once again Pampers thank-you for your kind and informative reply.
    Silence sometimes is the best course :) Maybe for both of us 8-)
    The beginning of the TOPIC is a RED QUESTION ICON
    The topic ends with my question.
    Again, silence is sometimes the best course
    Curious. Pampers do you have a BLOG? If so I will be interested in visiting.
    http://adnox.pl/
    Witam.
    nice web designs :)
    Why are you in Dublin?
    [ Edited by osco on 2010/1/23 20:47 ] :pint:
    [ Edited by osco on 2010/1/23 20:56 ]
    [ Edited by osco on 2010/1/24 8:25 ]
    [ Edited by osco on 2010/1/24 8:26 ]
  • »23.01.10 - 23:43
    xyphoid
    Posts: 870 from 2008/7/11
    actually I'd be curios too, if simple enough, since i have a multi-media keyboard....soo blog on!
    Posted with OWB ver. 1.6.1
  • »24.01.10 - 02:30
    Jambalah
    Posts: 820 from 2008/3/30
    Actually, both commands work. So mplayer -input cmdlist showed me them. I'm not able to explain them to you.. I mean usage..
    Try to give an eye to "input.conf" file too.
    If you are looking for other news or whatelse, see here:
    MPlayer doc
    Though the part explaininig how to configure commands is the same you found yet.
    MPlayer input config
    I don't know if MPlayer could use the multi-media keys, I've never tried to configure.
    Maybe using MMkeyboard program or something similar?!?
    Pegasos II 1 ghz
    Powermac G5 dual 2.0 ghz
    Powerbook G4 1.67 ghz 17
  • »24.01.10 - 07:19
    osco
    by Jambalah on 2010/1/24 4:19:59
    "Actually, both commands work. So mplayer -input cmdlist showed me them. "
    Pronto Jambalah!
    I tried again and I Got the list.. Many THANKS.
    The command list is extensive :) and all commands are accessable be AREXX by "RAW" <raw command>
  • »24.01.10 - 10:48
    osco
    by xyphoid on 2010/1/23 23:30:18
    Blog on!
    https://morph.zone/modules/newbb_plus/viewtopic.php?topic_id=6762&forum=9#69161 :-D  :-D  :-D
  • »24.01.10 - 10:56
