Someone should fix AmitradeCenter 1.4 ...
    keropi
    Posts: 131 from 2006/11/11
    I noticed that except amitradecenter , there is no other good ftp client (a GUI one) ... the latest 1.4 version , after a while refuses to work, and it hangs the whole system!
    I used it to transfer 4GB from my windows-ftp, then it hanged and it never worked again, even afer reboot/reinstallation...
    the previous beta one , ATC_beta_19012001.lha is working fine, but complains that there is no space on a hardisk that has 60gb free...
    so , a really updated version would be nice...
    I know there is samba/etc, but a true FTP client is more convenient and has more uses
    [ Edited by keropi on 2007/7/2 22:47 ]
    A4000D CS-PPC/G-Rex4000D
    A4000D CS-PPC/Zorro
  • »02.07.07 - 18:46
    CISC
    Posts: 619 from 2005/8/27
    The reason it hangs is because the Free space indicator is bugged (you will notice it reports completely wrong numbers) and crashes when the number wraps around a certain way (my guess is an overflow that nukes data on stack or otherwise trashes memory).
    The only workaround I know of until this is fixed (which it probably never will as last I heard UltraGelb had abandoned ATC) is to download to another partition (or RAM) where the crash isn't triggered (yet (or never if your partition will always have less than 4GB free (it can have more than 4GB free, but when the overflow produces a sufficiently large number it will crash)))...
    - CISC
  • »03.07.07 - 08:30
    jcmarcos
    Posts: 1178 from 2003/3/13
    Nested parenthesis!  :-D
    Nice tip CISC.
  • »03.07.07 - 09:02
    keropi
    a bug like that could explain the prob...
    I am now using the previous beta, that only shows wrongly the amount left on the target HD.... other than that the bars are correct and it works perfeclty...
    if only the source was available...
    A4000D CS-PPC/Zorro
  • »03.07.07 - 10:59
    Gelb
    Posts: 148 from 2003/3/4
    @keropi
    Make an offer...
  • »03.07.07 - 11:53
    weiseb
    Posts: 214 from 2003/3/29
    @ultragelb
    how about an offer for you fixing it?
    I would be in with 50 bucks
  • »03.07.07 - 12:33
    keropi
    Gelb wrote:
    @keropi
    Make an offer...
    hey you!  :-)
    fix it fix it fix it!
    +50$ from me
    A4000D CS-PPC/Zorro
  • »03.07.07 - 14:51
    magnetic
    Posts: 2129 from 2003/3/1
    Gelb
    Sounds like a bounty :) would be nice for new mos to have a nice FTP client with good eye candy gui..
    magnetic
  • »03.07.07 - 15:02
    keropi
    honestly, this is by FAR the best amiga FTP client...
    A4000D CS-PPC/Zorro
  • »03.07.07 - 15:48
    SoundSquare
    Posts: 1214 from 2004/12/1
    amiFTP works quite good here on MOS.
    an ATC fixed version would make me switch to it though.
  • »03.07.07 - 18:44
    kriz
    Posts: 312 from 2005/10/18
    Thanks for the tip with using drives less than 4gb free. Now I just
    download to ram, and runs stable and fine. before crashed whole
    system!!
    And update I would pay for aswell!!
  • »04.07.07 - 17:15
    Daff
    Posts: 250 from 2003/4/5
    Kryz : I use v1.1308 (02.11.03) here with MOS without problem.
    I fixed version will be very intersting for me.
    http://obligement.free.fr
  • »04.07.07 - 17:49
