MUI class problem
    Amigaz
    Posts: 121 from 2005/6/11
    Wanted to use my trusty Simplemail for email in MOS PowerUP on my
    A4000 but I get an error message that my NListTree.mcc MUI class is
    too old but I'm positive it's the latest (18.23) which
    I just downloaded and updates my MUI classes..both in sys and mossys
    After a reboot MOS and Scout still reports I have version 18.15!!
    I have even checked dates and filesizes on the NlistTree.mcc files in
    both sys, mossys and the folder with the latest NListTree classes and
    they match up (see screenshot)
    http://img292.imageshack.us/img292/5661/grabww6.png
    Now how can I "tell" MOS to accept I am using 18.23 and not 18.15? :D
    MorphOS PowerUP powered Amiga 4000
    Pegasos II G4 1ghz
    Radeon 8500 128mb
    Soundblaster Live 5.1 Digital
    Realtek 2139B 100mbit
  • »24.11.06 - 16:02
    Posts: 1521 from 2003/2/24
    My eyes!
  • »24.11.06 - 16:51
    If NListtree.mcc in Classes/MUI is right then bogus MCC is appearing from somewhere else. Are any other programs using NListtree.mcc?
    Also check are other NList classes up to date. Or ditch SimpleMail ;-)
    [ Edited by itix on 2006/11/24 20:59 ]
  • »24.11.06 - 16:57
    Amigaz
    itix wrote:
    My eyes!
     :-? too much eyecandy?  :-)
    Pegasos II G4 1ghz
    Radeon 8500 128mb
  • »24.11.06 - 17:38
    Amigaz
    problem solved..solution on amiga.org
    had made a clumsy assign in user-startup  :-P
    Pegasos II G4 1ghz
    Radeon 8500 128mb
  • »24.11.06 - 17:38
    klesterjr
    Posts: 196 from 2005/4/1
    You must be kidding -- MOS users are the KINGS of eye candy!  ;-)
    If I had to guess, I'd say he doesn't like the bitmap image you're using for listview mode.
    Heh, heh -- either that, or he has no taste! (speaking as the one who painted that theme!)
  • »24.11.06 - 18:04
    @klesterjr & Amigaz
    GUI theme is ok but magicwb pattern doesnt really match with it ;-)
  • »24.11.06 - 18:23
    Amigaz
    @Ken
    hehe, why do you think I wanted to run MOS?...for the eyecandy of course!! :D
    mmm..my windows backdrop isnt the prettiest one
    Can you recommend any good one's that fit well with the iMAZ theme?
    Pegasos II G4 1ghz
    Radeon 8500 128mb
  • »24.11.06 - 18:26
    Amigaz
    @itix
    yeah, it's no price winner ;)
    Pegasos II G4 1ghz
    Radeon 8500 128mb
  • »24.11.06 - 18:29
    klesterjr
    I use a pattern called 'beadboard' for icon-view (should be included in the theme as an MUI pattern) and gray gradient for list-view.
    Screenshot.
  • »24.11.06 - 18:51
    Amigaz
    @klesterj
    Just checked both the "MUI" folder and the "imAZ" folder in the
    "themeds" folder and there was no breadboard pattern there :(
    Great screendump by the way :)
    Pegasos II G4 1ghz
    Radeon 8500 128mb
  • »24.11.06 - 19:25
    klesterjr
    Amigaz wrote:
    Just checked both the "MUI" folder and the "imAZ" folder in the "themeds" folder and there was no breadboard pattern there :(
    Hmmm -- apparently I lied.  ;-)
    Download
  • »24.11.06 - 19:32
    Amigaz
    Thanks and...
    I forgive you :D
    Pegasos II G4 1ghz
    Radeon 8500 128mb
  • »24.11.06 - 19:36
