ixemul.library problem
    Motosampy
    Posts: 199 from 2004/8/14
    I get time to time ixemul.library message window saying just 'Abort' (see the attachment). How do I trace the source of the problem ? The requester pops up about once a day and almost always when the computer has not been used for a while... I've tried to use all progs separately but haven't had any luck so far.
    I have MOS 1.4.5 installed and running PegasosMixer, Blanky, Genesis tcp/ip, dnetc client, Ibrowse 2.3, MorphEd and Clonck...
    Darn, the requester does not show in the grab, but it's a requester titled 'Abort' with one button named 'abort'.
    [ Edited by Motosampy on 2005/5/18 20:29 ]
     Attached file(s)
  • »18.05.05 - 16:27
    Posts: 1521 from 2003/2/24
    No text in the requester?
  • »19.05.05 - 09:18
    aliem
    Posts: 85 from 2003/12/11
    | Abort! |
    |[ Abort ]|
    This is the requester (as far as I remember) It could appen when used something like MLDonkey, but don't remember.
    Now doesn't appears anymore ... bah
    ByE
  • »19.05.05 - 11:15
    Motosampy
    @itix
    no text, actually sgrab told me that it's ixemul.library message window, before that I had nothing.... Aliem has 'drawn' the requester correctly.
  • »19.05.05 - 14:32
    Motosampy
    Here's a new grab, I remembered wrong the part that there actually is no title... I had now Jabberwocky and Weather (+dnetc and Genesis) running, had been earlier this day using the programs mentioned in the first message...
    This is weird...
     Attached file(s)
  • »19.05.05 - 15:48
    Motosampy
    I disabled Samba a couple of days ago and have not had the problem since... (I can't even get samba to work with Genesis, was using earlier MiamiDx and Samba without any problems...)
  • »29.05.05 - 18:44
    liquidbit
    Posts: 408 from 2003/10/12
    ...this sounds spooky... when does it appear?
    :boo:
  • »29.05.05 - 18:56
    aliem
    randomly ... i haven't found a way to know why. In the ramdebug it say something like:
    ixemul: Abort!
    (now it doesn't appears anymore to me)
    It could appen because of the use of an old ixemul .. don't know
    ByE
  • »30.05.05 - 06:19
    alfie
    Posts: 96 from 2005/3/25
    Try to use Barthel non ixemul 68k samba, that works very well on mos.
  • »30.05.05 - 07:11
