configuring mplayer
    GMKai
    Posts: 259 from 2003/4/7
    I would like to have one configuration to use mplayer for playing vcd/dvd and files from hdd.
    For now I have an script that does vcd-playback and playback of files is started via ambient.
    another problem i have is to force mplayer in fullscreen but with e.g. 640x480 not 1024x768, which is not suitable for some videos i have around.
    with setting x=640 y=480 i can change windowsize but fullscreendisplay is not affected.
    i use mplayer 1.0 Pre 04
    what can be done about it?
  • »20.11.04 - 09:24
    Velcro_SP
    Posts: 929 from 2003/7/13
    I make use of the great Devedie by vovka to play DVDs and also video files (it opens up the file requestor for the video files).
    It wouldn't launch a VCD with a single button, like it does a DVD. I guess you can use the file requestor to select the mpeg file on the VCD. Maybe vovka would add single button VCD support.
    Don't know about your resolution question though.
    Pegasos2 G3, 512 megs RAM
  • »20.11.04 - 10:11
