Hi
I just sent this out by mail, it might be usefull to
anyone trying to compile my samba port..
You can not compile the source "off the shelf", it relies on file locking
and mem protection that morphos doesnt have. You have to remove all code
that refernce to locking and memoryprotection. Then with a bit of luck, the
source will build. I am trying to implement proper fcntl locking in ixemul
, but it was harder than I thought. The best thing to do is to start with
my source and try to compile it. There maybe is somethings that I hacked
during the development , that should be or not in the source when compiling
, you may have to change the code during the compile
I could have done the build for you , but my dev system just freaked out and
"make" does not work with the samba makefiles , and I have tried to
reconfigure the whole beast.
MorphOS hangaround :)
