oGALAXYo wrote:
The sources might be available but how much of it is in C and how much of it is in ASM ? Are the sources good enough to work on or will there be immense changes needed to adopt it to nowadays needs ?
This should be easy to find out by asking GP Soft. Perhaps they would even give a hint how much we had to collect.
Besides the normal changes for MorphOS there would probably be some extra work if the source needs to be adapted to build with gcc instead of SAS/C.
Look at the tool itself it's an entire Workbench replacement and I don't think it's philosophy fits into the Ambient design goal. Do we want to replace the Desktop again with a different application that doesn't even use MUI as the prefered Toolkit ? Do we want to "hack" and "patchwork" around as we did in former times or are we trying to go ahead with a Modern Desktop solution and have the Desktop itself do all the job for us ?
Why not? It's always nice to have a choice. Use the solution you like best.
That DOpus doesn't use MUI isn't a disadvantage. It would be if it were Reaction...
 I also like MUI and it would be nice to have a consistent look, but I think this is much less important than the quality of the useful functions of a program. In the case of DOpus, most of the time, the visual difference between DOpus as it is and a version using MUI would be minimal. The Listers are so compact so that the difference would only show in the config windows.
Since the OS is actively developed now a WB replacement also doesn't necessarily have to be "hack & patch". If some feature would be necessary it could be discussed with the MOS developers and be implemented cleanly for both sides.
Finally I'm not sure if the "modern desktop" you describe wouldn't get to large and bloated. We certainly don't want everything integrated into one piece like Windows. Also desktops like KDE are far too big for my taste. There's lots of stuff you don't need, but some things you need aren't there.
We want a slim but powerful system. If some decide that DOpus gives them that power that's fine. Others are free to use something else.
