What Should You Avoid While Using Kamagra Oral Jelly?
  • Visitor
  • Kamagra Oral Jelly contains sildenafil, which is used to treat erectile dysfunction (ED). If you are considering this medicine, understanding what to avoid can help reduce the risk of unwanted effects and interactions.
    One of the most important precautions is to avoid nitrate medicines, such as nitroglycerin, because combining nitrates with sildenafil can cause a potentially dangerous drop in blood pressure. You should also tell your healthcare professional about other prescription medicines, over-the-counter medicines, and supplements you use, as some may interact with sildenafil.
    It is also sensible to avoid excessive alcohol, as drinking heavily may increase dizziness and can make it more difficult to achieve an erection. Avoid taking more than the prescribed or recommended dose, and do not combine sildenafil-containing products with other ED medicines unless specifically advised by a healthcare professional.
  • »22.09.26 - 04:06
