geit wrote:
Sounds like your KVM is a little slow on the timing side.
PS: I assume you mean COMMAND Q and COMMAND R above, to reboot from Ambient blindly.
Correct, Geit! CMD+Q AND CMD+R, my bad.
My assumption was some sort of issue with the new monitor setup caused the Radeon to hunt around for a solution and hit a
(DDC per Geit) timeout... That is how it acted with the random success/fail displaying video upon longer than usual boot times. I think resetting the nvram was all she needed to get back on track.
The machine is back up and running. No magic involved, I just needed to step away for a while... I did check all my other bootinfo.txt files on my machines and they appear to be the same. I will have to learn about all this boot sorcery when I get a chance...
My OF commands on this G5 2.0 PCIe:
reset-nvram
set-defaults
reset-all
After rebooting and knowing that "ultra1" showed my bootinfo.txt :
setenv boot-command boot ultra1:,\\bootinfo.txt
setenv skip-netboot? true
reset-all
She is booting quick and reliable now.
FYI,
-EvX
[ Edited by EVX 23.10.2026 - 10:59 ]
