Buy MorphOS
    Tommes
    Posts: 2 from 2012/1/4
    Hi Guys,
    I looked at several MorphOS Sites and searched this forum but find nothing about how to buy a MorphOS license. Where should I buy one? Is there any shop or E-Mail contact?
    Thanks in advance.
    Tommes
    Das RETURN Magazin auf Facebook
    RETURN - Das 8-Bit Magazin
    Commodore, Atari, Nintendo, Sinclair, und viele mehr!
  • »04.01.12 - 20:25
    Tcheko
    Posts: 543 from 2003/2/25
    Hi Tommes,
    Install MorphOS and launch the regtool. You'll get an email for payment.
  • »04.01.12 - 20:39
    xyphoid
    Posts: 870 from 2008/7/11
    specifically MorphOs>Tools>RegTool
    Welcome to MorphOs :-)
  • »04.01.12 - 21:31
    Welcome to MorphOS and remember to look for and report the registration number from the email you receive. It lets us know how many licenses have been registered and if a fun statistic to keep track of as we get new users, or new registrations for existing users.
  • »05.01.12 - 02:10
    hooligan
    Posts: 1948 from 2003/2/23
    About-window of MorphOS was the first place I tried to look how to register, there really should be a link to regtool.
  • »05.01.12 - 03:23
    It could be a bit annoying for users that don't want to register right away (or at all), but I think having a popup requester that provides a button to launch the RegTool after each boot, or re-boot, is a good idea.
    It is just one click to ignore the requester and make it go away, and for newbies, it would be an easy way for them to go straight to the registration process after the install process was completed, if a keyfile is not found.
    If a keyfile is found, the process of putting up the requester would not happen.
    [ Edited by amigadave 06.01.2012 - 06:58 ]
  • »06.01.12 - 13:56
