Moderator
Posts: 2589 from 2003/2/24
A 5.6 with the BTO downgrade to 1.5GHz.... always knew they existed, never came across one.
Since this model only has 64MB VRAM your out of luck on dualhead support (as in the external DVI running it's own separate display).
It should have mirror output on the analog part of the DVI, so you got go down to VGA and then send this into a grabber.
Or you could try hocking up a digital monitor (so DVI or with DVI-HDMI cable) and close the lid right after poweron /reset. This way you might get a FullHD display that should easy to daisychain through grabber.
