MOS stops booting after firmware-upgrade!
    Granada
    Posts: 32 from 2003/12/30
    Hi all!
    I've just successfully installed the new firmware-upgrade from bplan, but now my system stops booting at the MorphOS-Splash-Screen!
    After the update all my BIOS-Settings were set back to sth. that looked like the systems wants to boot Linux. I tried to set my defaults but I might have forgotten something.
    Can anybody please post his printenv from the BIOS?
    I usually boot from /pci/ide/disk@0,0:0 and the bootfile is boot14.img
    Kind regards
    Ruediger
  • »05.04.04 - 17:47
    DrZarkov
    Posts: 142 from 2004/3/21
  • »05.04.04 - 18:00
    Granada
    Tja, genau das sind meine Einstellungen... klappt aber nicht!
  • »05.04.04 - 18:03
    DrZarkov
  • »05.04.04 - 18:07
    Granada
  • »05.04.04 - 18:09
    Frostwork
    Posts: 302 from 2003/4/18
  • »05.04.04 - 18:13
    Krashan
    Posts: 1107 from 2003/6/11
    You can take a look at my "photo-tutorial" in "pics from firmware upgrade" forum thread. Basically you just have to re-set your boot-device and boot-file environment variables in OF back to old values.
  • »05.04.04 - 18:22
    zacman
    Posts: 86 from 2003/2/26
    MorphOS 1.4.2?
  • »05.04.04 - 18:46
    Donar
    Posts: 142 from 2003/12/27
    boot-file = boot14.img
    no
    setenv boot-file boot14.img
    But your Pegasos II starts to boot, so this shouldn't be the problem.
  • »05.04.04 - 18:52
    Black_Eagle
    Posts: 70 from 2003/6/5
    Just wondering, did you remember to save the settings with "nvstore" ? I forgot that one a few times myself.
  • »05.04.04 - 19:03
    Granada
    Yep, I did store the settings with nvstore and they remain intact when checking them. :)
    Let me describe more precisely what my Peg2 does:
    Turning it on it loads the boot-image (boot14.img, MOS 1.4.2). It then pauses for about 2 seconds and then starts loading the rest of the system. It heavily access my IDE-Drive, where Ambient is on, until it shows the MorphOS-startup-logo (that blueish logo with the butterfly). Then it stops.
    I can even hear my scsi-disk being accessed (might be the moment ambient tries to bind the drivers?)
    Is ist possible to reflash the older update from december? Just wanted to have asked - I don't really think so. :)
    Kind regards
    Ruediger
  • »05.04.04 - 19:13
    tokai
    Posts: 1289 from 2003/2/25
    i never used nvstore. Dunno what's that is. :-)
  • »05.04.04 - 19:23
    hiTCH-HiKER
    Posts: 172 from 2003/12/31
  • »11.04.04 - 09:42
    AyoS
    Posts: 410 from 2003/8/13
    Does Your Scsi Drive have a bootable partition, namely 0,0?
    I found out that if the peg has a choice between booting
    the ide and the scsi, that it will stall. I corrected
    this by disconnecting the scsi drive and letting the Ide boot
    then changing my boot and mount options on the scsi so that
    they wont interupt each other.
  • »11.04.04 - 11:21
