Startup Problems
    Darkhawk
    Posts: 4 from 2004/1/2
    Well, I do have a problem, although I guess I know why it doesn't work..
    I just got my (free, isn't that nice? ;)) Pegasos2 some days ago, but since I lack a lot of the needed hardware, I had to cannibalize some of my other computers just to get it up and running. Anyway, I got it all set up, but I did not have one of the gfxcards listed in the manuals as worked. I figured I'd try my luck with what old gfxcards I had though, so I used an ATI Rage2 thingie, aswell as a Geforce1. Neither worked, or rather, the Pegasos2 boots up, displays the gfxcard information, and then just stands there, cursor blinking, not going any further (I guess firmware info is next or something). So, I guess this is because the gfxcards do not work with the firmware? Too bad, really wanted to take a look at the Pegasos and do a review for my magazine, but.. Oh well. Anyway, can anybody confirm whether this happens because of a wrong gfxcard, and are there any pointers as to what gfx card works, apart from the ones listed?
  • »02.01.04 - 13:59
    hooligan
    Posts: 1948 from 2003/2/23
    I also have tried ATI Rage, didn't work for me either. There is a list of compatible gfxcards somwhere.
    Don't forget to reflash the bios !!!
    EDIT:
    https://morph.zone/modules/xoopsfaq/index.php?cat_id=6#60
    also now Radeon 9200 is supported (I think)
  • »02.01.04 - 14:21
