Anybody got Shogo or Warzone 2100 to work on Efika?
    Zetec-s
    Posts: 198 from 2008/7/10
    Hi
    Just tried installing both Shogo (demo version) and Warzone 2100 on my Efika.
    Warzone opens a window, but I couldn't actually get it to do much after that, not sure if I was just being impatient and its a bit slow. Anybody got it to work on an Efika?
    Installed the Shogo demo, and it does take a while to load and when it does the graphics appear to be corrupted, and you can't really move around too well. Again not sure if the Efika is just a little underpowered, having said that shouldn't it work on a BlizzardPPC? Anybody got this to work? Any trick I'm missing.
    Thanks in advance
    Zetec-s
  • »26.08.08 - 20:51
    nujack
    Posts: 8 from 2006/9/8
    I tried the Shogo-demo on my Efika under MOS2.2 and it runs without corrupted graphic under accelerated 3D. I had to choose a screenmode 640x480 at the begining. I have a radeon-card in my efika.
    But I still get no sound. I only get the following error-message:
    "Could not initialize sound. Please make sure your sound card is configured correctly"
    I have selected AHI-unit 0 which should be efika:Hifi 16 bit stereo++
    Any hints are welcome.
  • »29.12.08 - 18:36
