MorphOS Partition Size
  • fmh
    fmh
    Posts: 75 from 2012/8/23
    Hello,
    I am interested in trying out MorphOS 3.1 on either my G4 Powermac or my G4 Mac mini. I know the mini will work fine. I did boot off the MorphOS 3.1 CD on the G4 Powermac and it did come up but to a 640x480 screen and no Network. I didn't mess around beyond that because I wanted to see if the old Dual G4-500 Powermac would boot and run MorphOS.
    I would like to setup one of these machines to dual boot OSX and MorphOS. My question is how big a partition should I setup for MorphOS? Is 10GB enough to get a feel for the OS or would I need more? I have no specific tasks in mind.
    Also would it be a better idea to boot to a separate drive inetrnal or external attached USB or Firewire? Granted the USB on the old Powermac would be slow so a Firewire would be a better choice there.
    Any input on this would be appreciated.
    Thanks
    [ Edited by fmh 24.08.2012 - 12:46 ]
    G5 2.0DP, MorphOS3.13
  • »24.08.12 - 15:38
    Tcheko
    Posts: 543 from 2003/2/25
    10GB is largely enough. Lower sane limit is 512MB which was the default system partition size in 2.x branch.
  • »24.08.12 - 15:53
