Question about Powerbook contrast
    Dougal
    Posts: 77 from 2010/10/22
    Sometimes (not always) after about an hour or 2 use the contrast seems to change on my powerbook. Screen looks sort of washed up, but not badly or anything like that, but not as nice as normal.
    It does not always do it.
    Any ideas? Maybe something needs resetting?
    Everything else works perfectly.
    Power Mac G4 1Ghz (Sonnet Encore) 640Mb, ATi Radeon 9000 Pro, USB 2.0
    OS: MorphOS 2.6 (Registered) , Mac OS X Tiger 10.4.11
  • »01.12.10 - 17:55
    Tcheko
    Posts: 544 from 2003/2/25
    Fact: heat washes LCD.
    [ Edited by Tcheko on 2010/12/1 21:31 ]
  • »01.12.10 - 18:30
