Impossible to install MorphOS on Mac..
    Jambalah
    Posts: 820 from 2008/3/30
    Hi everyone!
    I have a Quicksilver 2002 in wich I have installed Mac OS X Tiger and prepared the hard disk for MorphOS installation. I followed the Jacadcaps guide to do this, applying the little mod, as suggested by Boot_wb: I created two 30 m partition to use one of them with MorphOS boot.img and the other for a Linux system loader.
    So I created two 30 meg partitions, two 20,61 giga partitions (one for MorphOS, one for MacOS), one 16,70 giga partition for Linux and one 17,85 giga partiton for swap.
    Installed Mac OS and rebooted with MorphOS 2.6 cd in.
    Once loaded, I started IWizard and followed instructions til the IWizard - Storage window. I selected manual configuration and clicked on continue and the window showed the partitions I've created with alot more and everything doubled!
    If I run HDConfig I see four 28 k partitions, three 256 k partitions, two 30 meg partitions, one 128 meg partition and the 20,61 giga partition, another 128 meg and 20,61 giga partitions, the two linux partitions with the two 128 mega partitions and last one 8 k partition.
    Everything is selectable and modifiable without problem but when the partitions are showed in IWizard - Storage they become eight 28 k, six 256 k and so on. The only two partitions selectable and modifiable are the linux partitions. For all the others I obtain an "Invalid layout" error and I can't modify anyting so the installation can't go on.
    What is wrong? Or what I did it wrong?
    Why I have that strange hard disk configuration with all those mini partitions?
    THanks in advance!
    Pegasos II 1 ghz
    Powermac G5 dual 2.0 ghz
    Powerbook G4 1.67 ghz 17
  • »31.10.10 - 11:41
    Matt_H
    Posts: 30 from 2009/2/21
    The mini partitions are normal - something about the way the Mac does partitioning. You can ignore them.
    As to your other issues... I'm not sure. Did you use GParted to repartition?
  • »31.10.10 - 12:08
    Jambalah
    Thanks Matt! So I can ignore them.
    The problem then is: why when I start IWizard to install MorphOS 2.6 they double and the partitions for MorphOS are not selectable/modifiable?
    I didn't use GParted, I used the disk utility on Mac OS X install dvd to create all partitions.
    Pegasos II 1 ghz
  • »31.10.10 - 12:29
    Matt_H
    Not sure if there's a way to salvage your current layout, but you might try starting from the beginning again. I'm guessing there's nothing important on the drive right now.
    Boot from the OSX disc and do a full format/erase on the drive. Create a single, whole drive partition for MacOS and install it. Then use GParted from the Ubuntu live CD as described in the guide to shrink the Mac partition and create your new ones.
  • »01.11.10 - 02:20
    Jambalah
    Indeed, it's what I did! When I created partitions again I used OSX with the result to find the doubled partitioms when IWizard run. I checked again with mounter and I found 16 partitions instead of the 8 that should be...
    I will try again...
    Pegasos II 1 ghz
  • »01.11.10 - 08:19
    Divinity
    Posts: 501 from 2009/9/8
    @Jambalah
    use this "scheme":
    http://amiga.ikirsector.it/forum/viewtopic.php?f=40&t=14437&p=171281&hilit=yaboot+blessed#p171281
  • »01.11.10 - 09:51
    Matt_H
    Try repartitioning with GParted instead of OSX. I had no issues with it.
  • »01.11.10 - 22:03
