                Posts: 820 from 2008/3/30
				Hi everyone!
As usual surprises never ends...
This afternoon switching on Peg, MorphOS loaded withouth any problem. Tonight, after the firmware presentation, nothing happened.
Booted with MorphOS 2.4 cd and opened SFSDoctor, showed a DH0 without its name and after I selected this device and pressed 'Check Disk':
Checking Drive DH0
Checking root blocks
OK
Checking admin space containers
Error:unknown block type: 54524641 at block 5
There are errors in filesystem structure. It is advised to backup data and repair this partition
A request opened with a
DH0
has blockid error in block 262642
Expected was blockid 0x54525354
but the block says it is blockid 0xA1AD005C
No use at at all pressing 'Reread' so clicked 'cancel'
The transaction couldn't be re-applied
to the volume beacuse of error 540145592.
Please reboot to try again
Three questions:
1) How to backup DH0 to repair this partition?
2) What kind of error is 540145592?
3) What is admin space container?!?
If I click on 'Scan Disc':
Found a valid SFS root block on drive DH0
Readin object tree
Found 27419 objects
Checking extent tree
Done
and all the DH0 files are showed.
So is it wise to click 'Repair Disk'? I guess no and then how to act/solve without damages?
Thanks!
Pegasos II 1 ghz
Powermac G5 dual 2.7 ghz   I'll be back...
Powermac G5 dual 2.0 ghz
Powerbook G4 1.67 ghz 17
