Get ARexx working in MOS 1.4?
    nels664868
    Posts: 117 from 2003/12/28
    Does anyone know how to get Arexx working in mos 1.4?
    Every time I use a program the calls an arexx script, I get the error message 'Arexx reimplemention is not yet finished. If you want to use ARexx, please install your original rexxsyslib.library.'
    But if I copy rexxsyslib.library from my 3.9 cd to libs it still does not work.
    Ask Dr. Stupid,
    Dear Dr. Stupid,
    Why do we have to go to school?
    That's a very good question. It's becuse your parents are
    ALIENS!!! When your at school they shed there human skins and
    breathe drier lint! hahahaha!
  • »14.01.04 - 01:49
    ChatDEau
    Posts: 248 from 2003/4/4
    Hi there!
    Check out in the Top Downloads list on the left side. There's a tool I made called ISPatcher which patches installation scripts on MOS. And as that script uses AREXX, it also explains how to activate ARexx in MOS.
    Hope it helps!
    Fred
  • »14.01.04 - 01:52
    nels664868
    Thanx ChatDEau
    the instructions in the readme file worked.
    Ask Dr. Stupid,
    Dear Dr. Stupid,
  • »14.01.04 - 03:03
    ChatDEau
    My pleasure ;)
    Fred
  • »14.01.04 - 23:44
    cecilia
    Posts: 459 from 2003/8/30
    actually all i did was rename the mos rexxsyslib.library and use the 68k rexxsyslib.library in system/libs
    and ImageFX wrote the call to start arexx in the user startup file.
    so far i can run my arexx scripts in ifx just fine. (MOS1.4)
    but, i know nothing, so don't go by me  :-D
  • »15.01.04 - 00:20
  • Targhan
    Posts: 2833 from 2003/2/7
    Yo nels,
    You can also check the FAQ here on MorphZone about such things ;-) It isn't perfect, and doesn't always have what you're looking for--but we try!
    Oh yeah, what sounds better "faqs.morph.zone" or "faq.morph.zone"?
    :idea:Targhan
  • »15.01.04 - 05:36
    hooligan
    Posts: 1948 from 2003/2/23
    As long as it's not fags@morph.zone I am ok with it
  • »15.01.04 - 06:28
