Cant login to MZ From Ibrowse and Voyager!
    magnetic
    Posts: 2129 from 2003/3/1
    Attn: Targhan
    As of 3 hrs ago. I cannot login onto Morphzone from my Pegasos with IBrowse or Vger. It acts ike its logging in, but when screen refreshes I still get the login prompt. Sounds like cookie prob...
    plz help
    magnetic
  • »14.01.04 - 05:04
  • Targhan
    Posts: 2833 from 2003/2/7
    Sounds like a personal problem to me :-P
    Seriously, I think your settings might be hosed on your browser(s), since everyone else is using V and IB fine. I'de check your "HTTP Referer" settings, your Cookie security, and on V make sure you've set the cache-size to zero.
    :idea:Targhan
  • »14.01.04 - 14:32
    Jupp3
    Posts: 1193 from 2003/2/24
    Works here using A-Web :-)
  • »14.01.04 - 14:44
    Posts: 159 from 2003/10/24
    @Targhan and Magnetic
    I have seen the same issue with V on my Peg. If you click on a link your fine and the login prompt goes away but on the main page it is there. It only causes a problem if I want to use something from the usermenu or dyn menu from the front page. Not to much of a hassle. I haven't change any of my V settings from default either. I'll try and do some testing tonight and let you know what I come up with.
    --Mithalas
  • »14.01.04 - 14:53
  • Targhan
    @Mithalas
    Check HERE for information about how to get around the Voyager "cache bug" on MZ.
    :idea:Targhan
  • »14.01.04 - 15:38
