Snapshotting not working for other partitions.
    Doffo
    Posts: 508 from 2010/10/14
    Yoo!
    For some reason snapshotting a window will not work on my other partitions that I created. The only ones that snapshot right are System, Boot, Ram Disk, and My MorphOS. I have MorphOS 3.1 installed. I notice when you snapshot the main window for the ones that do snapshot, it will "redraw" quickly, and it worked. For my other two partitions, that doesn't happen, and it never snapshots right for both windows or icons. Just places the window towards the bottom-right side of my screen.
    Any help would be greatly appreciated. :)
    YUUUP!
  • »15.09.12 - 03:04
    Krashan
    Posts: 1107 from 2003/6/11
    Check if these partitions have "disk.info" file in their main folders.
  • »15.09.12 - 06:10
    Doffo
    Good idea! I will do that when I come back home and connect back my MOS machine.
    YUUUP!
  • »15.09.12 - 14:11
    boot_wb
    Posts: 874 from 2007/4/9
    One limitation is you won't be able to snapshot HFS+ partitions in place since they are read-only.
    It is possible, but requires snapshotting another (writeable) partition in place, then copying that disk.info onto the root of the HFS+ partition under OSX. When you reboot into MorphOS the two drive icons may be trying to occupy the same spot (can't remember tbh) - just move the writeable one somewhere else and snapshot it in place... a bit nasty, but it works if you really need it.
    Imho it's easier to just remove HFS+ partitions from the desktop - for the occasional need to access that partition it's still available through My MorphOS. (Personally I have no fixed hard drive icons on Ambient desktop at all anymore: double click for My MorphOS is cleaner, and removeable media are the only drives that show up - a useful differentiation).
    www.hullchimneyservices.co.uk
    Windows free since 2011!
  • »15.09.12 - 16:21
    Doffo
    I don't have any HFS+ partitions on my MDD. They were SFS ones for MOS. Just found it strange it didn't create disk.info already, but I will try it here in awhile.
    YUUUP!
  • »15.09.12 - 19:49
    Doffo
    Copying over disk.info from System to my other SFS partitions worked great! Now it will snapshot correct. Figured after you made partitions and formatted them, it would of made disk.info, but I guess not. Thanks for the help.  8-)
    YUUUP!
  • »15.09.12 - 20:18
