Posts: 680 from 2009/10/20
What is the name of the "Arexx" Rexx port?
Wish to force feed a batchlist of local html files to OWB? One way
1. make a batchfile with the shell command
list ram:#?.html lformat "file:///*%s%s*0 0" to ram:owb.bat
Now you should have a file in Ram: called owb.bat!
It will be a list of all your loca html's you sent that you wanted to be batch shown
Format file name: file:///ram:020021001.1-suf.html 0 0
Copy and paste your owb.bat file into
System:Applications/owb-morphos-1.7/Conf/sessions/"choose file name"
Then fire up FAB's OWB go to "load sessions " 7th down on project list and browse till you drop...
[ Edited by osco on 2010/4/29 18:35 ]
