change mp3 to wav/cdda
    GMKai
    Posts: 257 from 2003/4/7
    what app can i use in what way to convert mp3 to wav/cdda?
    lame seems to have that feature, but fails completly.
    what options beside --decode should i use to do the job?
  • »21.10.03 - 14:31
    GMKai
    sorry, it seems as if the mp3s were corrupt.
  • »21.10.03 - 15:01
    Spidey
    Posts: 568 from 2003/2/24
    Hi GMKai,
    Glad to hear you solved your problem. :-)
    Do you know of a program that can read/play WAV-files?
    Spidey
  • »21.10.03 - 18:39
    Robert
    Posts: 331 from 2003/5/12
    @Spidey:
    I know it's a bit "sledge hammer to crack a nut" but PSA can play
    wavs.
    Robert.
  • »21.10.03 - 20:56
  • jah
    jah
    Posts: 69 from 2003/3/24
    play16
  • »21.10.03 - 21:11
  • Targhan
    Posts: 2833 from 2003/2/7
    I'de like to see a mos-native play16.  ;-)
    :idea:Targhan
  • »22.10.03 - 00:06
    magnetic
    Posts: 2129 from 2003/3/1
    Spidey
    How are you? MOS 1.4 Multiview plays .wavs no problem... :D
    magnetic
  • »22.10.03 - 14:35
    Spidey
    Hi Magnetic,
    I'm fine. I was "out" for a couple of weeks, but now I'm back again :-)
    @Everybody:
    Thanks for the suggestions. I'll try them all :-)
    Spidey
  • »22.10.03 - 15:23
    GMKai
    can anyone else please verify that "lame.elf --decode input.mp3 output.wav" works under mos?
    thanks in advance
  • »22.10.03 - 18:07
    Robert
    magnetic wrote:
    Spidey
    magnetic
    Multiview? Cool!
    I had no idea it could play sound files. anything else Multiview can do that I might not know about?
    Robert.
  • »23.10.03 - 07:43
    Robert
    Hi folks,
    I'm now looking to convert wavs to mp3. I downloaded lame
    but haven't the foggiest idea how to work it.
    Are there instructions anywhere?
    -EDIT-
    I've found the html. do I have to install lame in C or something,
    then tpye the commands in a shell?
    Excuse my ignorance. :-/
    Robert.
  • »28.10.03 - 20:35
    Captainthunder
    Posts: 14 from 2003/10/29
    Download secondspin, A fantastic sound-converter which uses lame.
    Convert from CDDA/WAV/AIFF/MOD to mp3 or mp3 to WAV etc. in all bitrates, qualities you wish.....
    very easy to use...A amiga programm to be proud of
    I've tested this with MOS 1.3 allready....it runs perfect and very fast!!!
    Mattijs
    http://www.helsinki.fi/~lakahone/amiga/secondspin/
  • »29.10.03 - 05:29
    Robert
    Cheers - downloading secondspin now.
    Robert.
  • »29.10.03 - 19:13
