Can't connect to MorphOS VNC Server
    Posts: 236 from 2003/7/28
    Hi All, on my home network I cannot connect to my MorphOS 2.2 based Pegasos 2 that has VNC Server running. (I am using Piru's latest version, which is 1.0RC4 I think).
    Anyway, I checked with a port scanner and port 5900 is open. I have tried with TightVNC and RealVNC from other machines on my home network. I can ping the Pegasos 2 and it replies, so that is no problem.
    Tight VNC gives me a log file, it is below:
    Connected to 192.168.1.10 port 5900
    reading 12 bytes
    RFB server supports protocol version 3.8
    writing 12 bytes
    Connected to RFB server, using protocol version 3.8
    reading 1 bytes
    reading 1 bytes
    writing 1 bytes
    Choosing security type None(1)
    Authentication scheme: (null)
    reading 4 bytes
    Authentication successful
    Clipboard changed
    Don't send initial clipboard!
    writing 1 bytes
    reading 24 bytes
    Deregistered connection from app
    Exiting
    VNC viewer closing down
    BTW, I have allowed TightVNC through the windows firewall.
    Anyone have any ideas?
    Thanks
  • »14.04.09 - 20:49
    Ok, delete or disregard this post.
    I was able to get it working by deleting the program and prefs files and reinstalling....I must have screwed something up in the prefs.
  • »15.04.09 - 02:15
