Howto install the SDK?
    mvdhoning
    Posts: 5 from 2008/7/1
    Following the instructions on http://morphos-dev.net/files/mossdk_install.txt
    i fail on step 5: starting the installer. Double click on does nothing. starting the installer from command line states that is not executeable. Applying a v to Script and then run it again it states that an command is not available?
    Thanks for your answer(s) in advance.
  • »03.07.08 - 18:03
    magnetic
    Posts: 2129 from 2003/3/1
    Are you trying to install the 1.4.5 SDK with 2.0? Please wait for the new SDK release hopefully soon for morphos2
  • »03.07.08 - 19:46
    guruman
    Posts: 461 from 2003/7/21
    The SDK master, CISC, is on vacation right now, and he already said that we should wait until he can polish up the release, so I wouldn't expect a new SDK before September... Better try out the old one in the meantime!
    As for the problems, you probably need the Installer in C: . Download it from Aminet (the original 68k AmigaOS will do, although I saw a MorphOS native replacement...).
    Kind regards,
    Andrea
  • »03.07.08 - 20:13
