Scout not working anymore
  • tom
    tom
    Posts: 148 from 2003/7/22
    I've used scout for a long time, but since some months after a new installation of my morphos partition i can't get it working again. Starting is no problem, but even closing a window doesn't work anymore.
    I've installed identify.library
    Snoopium doesn't give a clue.
    regards Tom
  • »19.07.07 - 09:18
  • tom
    tom
    A lot of people have read my question, but no answer. I guess I'm the only one with this problem?
    I tried a new installation, but no difference....
    HELP!!!
    Regards Tom
  • »21.07.07 - 18:33
    Posts: 1520 from 2003/2/24
    Unfortunately MorphOS build available at Aminet is broken... it is probably reason. I guess I should look for new release soon.
  • »21.07.07 - 18:54
  • tom
    tom
    THAT WOULD BE NICE.
    Thank you.
    Regards Tom
  • »22.07.07 - 05:31
    diezi7
    Posts: 167 from 2005/7/25
    Did you tried this download?
    http://www.morphos-news.de/software.php?lg=en&search=scout
    Maybe this 3.4 version works for you
    Pegasos II G4 (not working)
    Powerbook G4 1.0 15"
  • »24.07.07 - 04:50
    Posts: 108 from 2005/4/3
    Hi all,
    That's right, newer Scout versions have bugs. I've version 3.5 with appropiate libraries. I did send a bugreport a time ago. Don't remember what bugs.
    Grts, Amigaharry
    http://www.angelfire.com/amiga/ex
  • »24.07.07 - 14:14
  • tom
    tom
    Since my Peg II died I'm using my old Peg I. On my Peg II Scout worked without any problem. It is on my Peg I that Scout doesn't work anymore. Strange.......
    Regards Tom
  • »24.07.07 - 19:35
    diezi7
    What happened to your Pegasos II?
    Died all the motherboard, or the CPU card burnt out??
  • »24.07.07 - 19:48
  • tom
    tom
    I sent it up to Vesalia and they sent it up to BPlan.
    The fan didn't work anymore and the computer stopped completely with everything. No video, no harddisk-activities etc. They repaired the G4 but I still can't link to to the HD. I can connect to the CD, but can't find the HD.
    The same HD works fine with my Peg !. (After switching the Boot.img)
    Regards Tom
  • »25.07.07 - 08:52
  • tom
    tom
    Still no luck. I don't think it's a bug in Scout, because I installed the back-up. And that worked fine for me till I got that terrible crash.... There must be something in my setup, but I can't find or think what the problem is.
    Regards Tom
  • »26.07.07 - 08:07
    dIGIMAN
    Posts: 273 from 2005/11/7
    I also had problems with never scout versions, chrashed on startup.
    I downgraded again and everything went back to normal.
    Try to boot from your MOS CD and run scout, then you may know if its ur setup
  • »26.07.07 - 10:32
  • tom
    tom
    I tried using Scout with bootimng from the Morphos-CD and.... It works without any problem. Ater that I tried again with starting from HD. It still doesn't work!
    This is very strange. I don't no where to look....
    Regards Tom
  • »28.07.07 - 13:57
    Framiga
    Posts: 363 from 2003/7/11
    Mui classes, identify.library ...
    Check to don't have different identify library versions in Scout:Libs/ and SYS:Libs/ (or worse in MOSSYS:Libs/)
  • »28.07.07 - 14:49
