New Ambient Version MimeTypes!!!
    GK_LKA
    Posts: 481 from 2004/3/28
    You can also write an AmigaDOS script and call that to do what you want ;)
    [ GK / LKA Team ]
  • »19.03.07 - 16:14
  • Fab
    Fab
    Posts: 1331 from 2003/6/16
    It's "merge selection" checkmark, and i added that on 10th March, so it should be in that 11th March build.
    If it's not checked, the action is indeed applied for each entry. About quotes it's "normal", "don't quote" seems to have another meaning internally. It's quite easy to strip them from an arexx script (more or less with the rexx line i gave earlier).
    Command evaluation backquotes seem to work here. If i just set "echo `c:requestfile`", it just works fine and prints what i selected.
    [ Edited by Fab on 2007/3/19 18:58 ]
  • »19.03.07 - 16:57
