Tvcards supported?
    amiga4001
    Posts: 449 from 2006/11/16
    I took the tv card out off my amiga4000 with mediator setup.
    This was a working combination(tv card with BT878 chipset) no brandname.
    Thought I could use it in my peg 2 to maybe record tv.
    But is not supported.
    Tried this amithlontv but no go..
    How can I tell what brand the card is?
    And what is a good card for the peg?No fancy one just for tinkering.
  • »31.12.06 - 20:02
  • HAK
    Posts: 225 from 2003/2/24
    Hi
    Well, have you tried Visionary? Maybe you have more luck with it.
    I had a LifeViewII (sold to a friend) and now a Hauppage TV card in my Peg2 and both worked with AmithlonTV and Visionary.
    There is also btr_8x8 available - though I never had much time to tinker with this one, as it was rather unstable for me.
    I made snapshots with AmithlonTV and VHI-Studio; don't know whether there are other programs available.
    VHI-Studio supports recording, unfortunately this is very unstable here.
    Oh, there is also a program called ValiantVision in work - however, this one still takes some time AFAIK.
    Concerning the brand of you TV-card: Maybe you have some luck if you try PciTool and it can give you some hints.
    Bye HAK
  • »31.12.06 - 22:54
    amiga4001
    Thanks for your tips.
    Seems like my card ain't supported.
    Tried all programs I could find.
    But if recording ain't possible I'll stop the search here.
    Too bad would made a nice "VCR"
  • »02.01.07 - 20:29
