Please help
    zephar123
    Posts: 139 from 2004/3/8
    Ok im completelty goign coocu here :(. I was thrilled to get my peg a spot and setup again =). ANy how heres the wierd thing and ive tried reinstalling the os ive tried everything. If i boot the hd by itself it boots right up np, But if I try to boot with the cd rom drive hook up I get as far as the buterfly and it never boots the rest of the way :(. Any ideas as im really stumped.
  • »31.03.06 - 22:09
    warface
    Posts: 653 from 2003/2/24
    No idea - maybe if you put it on the other IDE channel?
  • »01.04.06 - 09:59
    Kamul
    Posts: 121 from 2004/6/9
    Maybe it's obvious, but are you sure the CD isn't broken?
  • »01.04.06 - 10:28
    Robin
    Posts: 741 from 2003/2/24
    Right ide cable? (80 wires) Cable broken?
    Master/Slave jumper correct on both devices?
    Bad timeing? Add a "wait 1" after LoadMonDrvs
  • »01.04.06 - 10:31
