PEGASOS - PC ETHERNET CONNECTION
    cbrxx1100
    Posts: 22 from 2005/3/18
    Hi guys!
    I am having a problem concerning an ethernet connection with a cross cable between my pegasos and my pc.
    I am able to use the pegasos internet connection through my pc. I am also able to play quake ii through network. THE PROBLEM STARTS WHEN I AM TRYING TO FIND A SHARE FOLDER IN ORDER TO EXCANGE FILES BETWEEN THEM.
    DOES ANYONE KNOWS HOW TO MAKE AT LEAST ONE OF THEM TO SEE THE OTHER ONE?
    Thanks in advance guys
    George
  • »28.09.05 - 11:31
  • TCD
    Posts: 5 from 2005/9/4
    You need install samba server or there is another way :-)
    From a PC side you have to establish FTP server, and on pegasos side just run Amitrade. After this you will be able to exchange data between your machines.:-D
    Actual Machine: Pegasos2, G4 1Ghz, 512 Mb Ram, Radeon 9250 128 Mb, Soudblaster Live 5.1, Samsung 160 Gb, BTC DVD-RW 8x drive, All together in lovely Antec Aria case.
    Operating Systems: MorphOS 1.4.5, Ubuntu Breezy Linux, MacOSX 10.3.9 (Linux emulation)
  • »28.09.05 - 11:52
    tarbos
    Posts: 221 from 2003/4/19
    FTPMount ;)
  • »28.09.05 - 12:11
    Golem
    Posts: 766 from 2003/2/28
    You can use smbfs to access smb shares on your pc from MorphOS.
    Btw. I think your caps lock key might be malfunctioning.
  • »28.09.05 - 16:57
