Pixel32
    serge
    Posts: 725 from 2003/2/20
    @ gunne:
    Thank you very much for the way how to run pixel from Ambient. It's a
    simple and elegant way.
    To load a picture, I have found a solution. on the morph.ini file
    there is this line:
    BrowserDirectory=sys:
    I replaced it by
    BrowserDirectory=MorphosHD:Apps/Pixel32/Pictures
    and now I can load files from this path.
    cool  ;-)
  • »10.04.05 - 16:07
    ossian1961
    Posts: 123 from 2004/7/31
    @Robin
    I tried to run it in command line but after a quite long list of variables not found the prog fail to start
    with:
    Failed to initialize PowerSDL library.
    I put it in LIBS folder. :-(
  • »10.04.05 - 16:45
    Robin
    Posts: 741 from 2003/2/24
    @ossian1961
    Are you sure you've a current version of PowerSDL ?
    powersdl.library 10.5 (14.01.05)
    Check if you have different versions of the lib
    in SYS:Libs and MOSSYS:Libs .
    There are some new libraries added to the powersdl.lib
    Dont know if you need them ... but it cant hurt to
    check for them too ...
    powersdl_net.library 13352 ----rwed Gestern 18:25:17
    powersdl_ttf.library 504472 ----rwed Gestern 18:25:17
    powersdl_image.library 641688 ----rwed Gestern 18:25:17
    powersdl.library 352044 ----rwed Gestern 18:25:17
    powersdl_mixer.library 195404 ----rwed Gestern 18:25:16
    powersdl_gfx.library 76772 ----rwed Gestern 18:25:16
  • »10.04.05 - 17:59
    ossian1961
    @Robin
    I 've replaced the 8.01 rel. with the 10.5 and now it starts! Uauh! If I draw a new image it semms ok, but when I try to open an image Pixel32 goes crash. I'm agree with Acill I'll buy it when it will be more stable. I hope Pixel32 team tell us good news.
  • »10.04.05 - 18:41
    Robin
    @ossian1961
    When you can afford it buy it now :-)
    The more users support Pixel32 the more
    support we'll get from Pavel :-D (He's not a team ;-) )
  • »10.04.05 - 18:46
    Chain-Q
    Posts: 350 from 2003/10/12
    There is no such thing as Pixel32 team. :-) At least officially. But if you want good news, i think we've found (together with Pavel) what causes the random crashes here and there. Stay tuned. :-D
    [.Hosting AmigaSpirit.hu.]
  • »10.04.05 - 18:54
    serge
    @ Ossian:
    Have you edited the morph.ini file ?
    Have you replaced the line:
    by
    BrowserDirectory=your pictures path?
    For me is:
    Please, dont browse your had drive cause the file browser is broken.
    Just load your file from the place yuo indicated on the morph.ini
    file.
  • »10.04.05 - 19:03
    ossian1961
    @Serge
    I've tried to change the path in the morph.ini but the Pixel32 goes crash again.
    @Chain-Q
    You and Pavel are making a great work and I 'll buy Pixel32 next days. :-D
  • »10.04.05 - 19:28
    serge
    I registered it today ;-)
  • »12.04.05 - 18:11
    Posts: 979 from 2003/6/28
    http://www.morphos-news.de/comments.php?lg=en&nid=1060
    People want a MUI style in the interface, not like the windows/linux interface, says that has potential but too buggy actually... I prefer the MUI style too... I consider that, being the program very skinnable, probably can be adapted for look as the native widgets of the running platform...
    But, uhm...anybody seen this?
  • »12.04.05 - 19:35
    serge
    very nice !
  • »12.04.05 - 19:43
    killlbilll
    Posts: 95 from 2004/5/19
    Good work Pavel and Chain|Q, Pixel is progressing nicely. BTW: Is the fullscreen-bugginess related to the SDL-implementation?
    [ pegasos ii / g4 | morphos1.4.4 ]
  • »12.04.05 - 20:10
    killlbilll
    Any news on bugfixed Pixel32 yet?
  • »12.05.05 - 09:32
    Posts: 1520 from 2003/2/24
    @killbill
    Window resize bug in fullscreen mode is fixed in the next PowerSDL release.
  • »12.05.05 - 11:40
    PowerSDL will be built-in into the next MorphOS version?
  • »12.05.05 - 18:26
    @timofonic
    Not necessarily "built-in" but a contribution. PowerSDL needs constant updating and at some point libraries on the CD are older than the newest available.
    (Thus it is likely V11 update doesnt install libraries to MOSSYS:Libs anylonger but uses standard LIBS: instead.)
  • »12.05.05 - 20:11
