ASL requester height
    MarK
    Posts: 641 from 2004/1/25
    Hello everybody!
    I have a question, is it possible to change the default ASL requester settings? I loved the ReqTools for it's settings... Now, when I open a requester, it's usualy a small window, where only few items are visible... I'd love to set it up to atleast 80% of the screen height. (I mean automaticaly) Is this possible? How?
    Thanks a lot!
    Bye, MarK.
  • »03.01.05 - 16:09
    stony
    Posts: 32 from 2004/4/18
    Try MagicASL.
  • »03.01.05 - 19:26
    Posts: 17 from 2003/4/4
    Yes try MagicASL.
    But this is a 68k class. And need an update, like a option to change the colors of fonts.
  • »03.01.05 - 19:57
    Schlonz
    Posts: 131 from 2004/4/16
    as I think that ASL sucks quite a lot, I used to use since the Classic Amiga times "Reqtoolspatch", which does redirect all ASL requesters to Reqtools requesters. It works very good on my Peggy, too.
  • »03.01.05 - 20:56
    MarK
    Wow! Does the ReqToolsPatch really work? I also loved the ReqTools... But... now I'd like to use more capabilities of the new ASL, like possible directory creation (iirc, this also worked in some cases under RT) and ofcourse mousewheel, which IMO should scroll only contents of the window, not to select it's items...
    Anyway, thanks for answers, I will check it all out!
    Bye, MarK.
  • »04.01.05 - 05:07
    Schlonz
    Hi MarK,
    Reqtoolspatch does work great for me. But the mousewheel does not work with it on MOS - on AOS3 it did work - and, of course, none of the new ASL stuff works with it. But hey - you get Reqtools requesters, which do rock!
    See ya,
    Schlonz
  • »04.01.05 - 10:18
    MarK
    Well, if there are sources for ReqTools (I guess it's not under development anymore), it shouldn't be a problem to add more features like the mouse wheel. I'd say, that it's very simple to add such feature and even more...
    Bye, MarK.
  • »05.01.05 - 09:43
    brotheris
    Posts: 142 from 2003/2/24
    IIRC AROS cvs has reqtools sources. Try it %-)
    Home sweet home is Pegasos User Group Lithuania
  • »06.01.05 - 06:49
