Morphzone & CGI:IRC
    maurensen
    Posts: 358 from 2003/10/3
    Maybe this is a bug or a new Mos feature, who knows :-)
    About a month or two ago browsing MorphZone with VoyagerPPC (under
    MOS, of course!!) and cliking login on the left bar of CGI:IRC i was
    able to chat in IRC via the browser. Very nice! Now, if I try I get a
    Voyager window with the welcome message at ch1.arcnet.blabla but in
    the right frame a Loading message appears and nothing else is
    displayed.
    What's happened to this nice feature? :-;
  • »08.10.04 - 16:33
  • Targhan
    Posts: 2833 from 2003/2/7
    I don't remember making any changes to cgi:irc's configuration on the site. It should still work (saving a change in Voyager's settings on your machine). It's still worth looking into from my end, thanks for the info.
    :idea:Targhan
  • »08.10.04 - 19:33
    Aaron
    Posts: 127 from 2003/6/14
    @maurensen
    Are you sure you were using Voyager? I have never been able to
    use CGI:IRC with Voyager. It works with the other two browsers,
    though.
    --Aaron
    --Aaron Diezman
  • »08.10.04 - 22:53
    maurensen
    Oh yes, I was using Voyager, it's the only browser I use
    to surf Internet with my Peg...
    Bah, I'll try 1 day to install some IRC proggy.
    Could yoy tell me what Should I use and how to configure it to chat
    under #MorphZone?
    Thanx and ciao!
  • »10.10.04 - 14:14
