FTP client
    Motosampy
    Posts: 199 from 2004/8/14
    I'm maintaining a web site and was using ATC for transfers with my old Amiga, but there seems to be some incompatibility with MOS and ATC, can upload only 1 file at time, downloading doesn't work at all, so I'm open to suggestions for an easy-to-use FTP client (GUI is a must!) for MOS.
    So far tried SimpleFtp and GUI-Ftp from Aminet, do not work.
    - Sami
  • »21.09.04 - 19:21
  • Targhan
    Posts: 2833 from 2003/2/7
    Try the 2001 version of ATC.
    Try OpusFTP (built into Magellen).
    Try FTPMount (aminet, a bit annoying to set up, but it will treat your ftp account like a drive!)
    -Targhan
    :idea:Targhan
  • »21.09.04 - 19:41
    MarK
    Posts: 641 from 2004/1/25
    Hi there!
    I use MFTP, it's small and MUIed... Doesn't provide many features, but it satisfies me :-)
    Bye, MarK.
  • »22.09.04 - 08:58
    Ingo
    Posts: 103 from 2004/3/19
    ATC still works on MorphOS. Try to get the latest version ;)
  • »22.09.04 - 15:04
    Motosampy
    I downloaded the xx.Dec.2001 version of ATC and it works fine with MOS. The latest does NOT (at least here it freezes if trying to upload multiple files or download anything).
    Thanks everybody !
  • »22.09.04 - 16:16
    Jupp3
    Posts: 1193 from 2003/2/24
    on my Amiga I had problems with some ATC version when trying to upload / download seweral files.
    It got stuck when I tried dragging many files, but worked if I used send / receive buttons instead of dragging.
  • »22.09.04 - 17:41
    Yvan
    Posts: 79 from 2003/3/28
    I also had problems with ATC. Freezed after one or more downloads. OpusFTP works great.
  • »23.09.04 - 10:17
