Dialup problem with Miami
    Leon
    Posts: 93 from 2003/11/28
    Hello,
    I moved temporarily to a place where I don't have broadband or ethernet access. However, I have the good old dialup option. I connected a 3Com USRobotics 56K EXT Modem to the serial port of my Peg2 and tried to get online with Miami.
    Unfortunately I couldn't manage it to get online. MiamiInit succeeded just once to connect and I saved my prefs then loaded them in Miami, but when it comes to configuring PPP or DNS things, Miami can't go online. I also realized that it has problems resetting or identifying the modem. I think that the serial device may have problems and I don't think my system is stable. I don't think I have an incompatible modem, so what's wrong? Should I make special settings with Miami?
    Guvenc
    Proud owner of:
    Efika
    ABIT ATI 9200SE AGP 128MB
    40GB Samsung Hard Drive 5400rpm
    PowerMac 3.1 G4 350Mhz "Sawtooth" AGP
  • »24.07.04 - 17:38
    Robin
    Posts: 741 from 2003/2/24
    The only idea I have is that perhaps you boot
    without the "ramdebug" option ?
  • »25.07.04 - 04:45
    Leon
    Should I? Does everybody boot with ramdebug option?
    Proud owner of:
    Efika
  • »26.07.04 - 15:11
    Robin
    The pegasos in it's current setup sends out debug informations
    to the serial port. So when you want to plug any serial unit to
    it you have to tell the system to direct the output elsewhere.
    RamDebug means that it's written to ram ... getramdebuglog is a tool
    to read it from there when needed.
    When you dont switch the debug off it's no wonder your connection
    has problems and is flakey ;-)
  • »26.07.04 - 23:03
    ChatDEau
    Posts: 248 from 2003/4/4
    @Leon
    I would first try the most appropriate Init String before going more deeply into this issue.
    Check out on Modem Help, especially here for you.
    The first init I'd try (according to the model you mentionned) is "USR 56K modems" -> AT&F1&D0S15=128S32=32
    Hope it helps!
    Fred
  • »27.07.04 - 13:46
