Can I mount NTFS filesystem on MorphOS?
    Leon
    Posts: 93 from 2003/11/28
    I have a PC harddisk and connected it to my Peg2, however the partitions are in NTFS format, is there a way to mount these partitions so they get accessible on Morphos/Amiga?
    Guvenc
    Proud owner of:
    Efika
    ABIT ATI 9200SE AGP 128MB
    40GB Samsung Hard Drive 5400rpm
    PowerMac 3.1 G4 350Mhz "Sawtooth" AGP
  • »17.07.04 - 10:38
  • News Moderator
    News Moderator
    Darth_X
    Posts: 571 from 2003/2/10
    Even windows98 can't directly access NTFS partitions. Look at 'what kind of hoops you'd have to jump through' (figure of speech) to access NTFS from windows98 (and this solution is READ only) HERE
  • »17.07.04 - 12:01
    Leon
    On Linux you can mount NTFS filesystems. Why is it not possible under MorphOS?
    Proud owner of:
    Efika
  • »17.07.04 - 17:06
    cecilia
    Posts: 459 from 2003/8/30
    but even under linux it's a READ only mount.
  • »17.07.04 - 18:45
    Posts: 54 from 2004/6/16
    'course you could bung it in an old PC and use Samba ... that would be read/write.
    Also IIRC 'NTFS 5' (Win2K/XP) can't be read directly from NT4 (if you install 5 over 4 it does a conversion thing).
    -~= Amiga Cats don't get Microsoft worms! =~-
  • »17.07.04 - 20:41
