File size limit
    Hawk
    Posts: 204 from 2003/12/29
    I tried moving a 4GB ISO file from a Linux partition to a SFS partition, and I get:
    File size limit exceeded
    I thought that the limit was just with the old dos.library, not with SFS itself. Is is a limitation of the linux driver?
    BTW, anyone know how long will we have to wait for BurnIT 3.0?
    cya!
    Pegasos II G3@600Mhz (no fan) 512MB RAM (1 slot)
    -- Maxtor 6Y120P0 120GB, 7200 rpm -- ATI Radeon 7500 - (64MB, TV-out)
    -- Minuet Slimline PC case -- MorphOS 1.4.5 + Gentoo
    EFIKA
  • »08.06.04 - 14:41
    GK_LKA
    Posts: 481 from 2004/3/28
    I have the same problem. On pc I had a lot of troubles with 4GB+ files, and I always said, that there will no problem if I had a Pegasos, but - there is. AFAIK SFS supports large files, but the dos.library don't. I hope it will change in 1.5.
    [ GK / LKA Team ]
  • »08.06.04 - 15:45
    Hawk
    But from the Gentoo side, the dos.library has nothing to do, I guess.
    Anyone knows who is the responsible of the developing of the SFS support on the linux kernel? Last version is 0.6?
    cu!
    EFIKA
  • »08.06.04 - 23:54
    Posts: 979 from 2003/6/28
    The 4gb limit MUST be fixed on both sides: MorphOS & Linux.
    On a new OS as MorphOS we can't have these limitations of older OSes...
    MorphOS 1.5 will be free of these limitation? Please say it...
  • »10.06.04 - 03:06
    GK_LKA
    Does the latest unstable debian contrib have this problem too? I'm disappointed... :((
    [ GK / LKA Team ]
  • »10.06.04 - 16:58
    McGreg
    Posts: 17 from 2003/4/16
    MorphOS1.5 will have a 64bit DOS.
    It will support files >4GB. Still the problem is, if the Filesystem support files >4GB. SFS does not.
    Greg
  • »11.06.04 - 06:21
    Black_Eagle
    Posts: 70 from 2003/6/5
    Neither does PFS. 2GB limit on that too.
    OnyxSoft - Amigans never surrender, they know they can do it better...
  • »11.06.04 - 11:38
    GK_LKA
    Hmmm... :))
    Will itt require a support from programs, or can the existing stuffs use this functions too?
    [ GK / LKA Team ]
  • »11.06.04 - 13:18
