Problems formatting SFS partition
    Hawk
    Posts: 204 from 2003/12/29
    I have a 120GB disk, and so far I had made 7 partitions: FFS, (Reserved - For MacOS), SFS (4GB), Linux, Linux Swap...
    I wanted to add a last partition with the rest of the space (86GB), in SFS format. As the Peg2 manual suggests, I put 600 buffers, block size 512, Mask 0xfffffffe.
    When I try to format it, the format process stops after a while (11.6%, 29% in the second try...). Actually, this happened before when I formatted the other SFS partition, but I thought it was because I was multitasking, since it went OK in the 2nd try...
    Any idea? Should I retry and retry until it works? SFS can handle big partitions, right? Should I give up MorphOS and live my life in Gentoo Linux? ^^;
    Pegasos II G3@600Mhz (no fan) 512MB RAM (1 slot)
    -- Maxtor 6Y120P0 120GB, 7200 rpm -- ATI Radeon 7500 - (64MB, TV-out)
    -- Minuet Slimline PC case -- MorphOS 1.4.5 + Gentoo
    EFIKA
  • »17.04.04 - 00:55
    Senex
    Posts: 498 from 2003/2/17
    Sounds familiar, had the same problem with the Pegasos I - so I suppose you can just retry again and again or consider to split the rest of the harddisk into smaller partitions to increase your chances to reach 100%.
  • »17.04.04 - 06:29
    Hawk
    I formatted it using Quick Format ... is it safe to work with the disk having it formatted like that?
    EFIKA
  • »17.04.04 - 07:10
    brotheris
    Posts: 142 from 2003/2/24
    I personaly never used full format on hds, the wait with big hard disks ir very long and imho not needed. I'll assume that it is safe to use. How about others ?
    Home sweet home is Pegasos User Group Lithuania
  • »17.04.04 - 07:49
    Hawk
    When I mount the quick formatted partition under Linux, I can not see any file, just dirs... (;_;)
    EFIKA
  • »17.04.04 - 07:52
    Posts: 1520 from 2003/2/24
    Quick format is enough. Full format is only waste of time.
  • »17.04.04 - 09:07
    Hawk
    I went with the quick format. Thanks. The problem with the files under Linux was that I had quick-formatted the SFS partition with the Case-Sensitive option.
    Without that option, the partition works fine under Linux.
    EFIKA
  • »18.04.04 - 00:25
    Posts: 9 from 2004/4/17
    According to the SFS-doc from aminet:
    Also be careful with the standard Format command! Always use the QUICK option for drives larger than 4 GB, otherwise format may format information in the wrong area of your disk!
    Don't know if this is relevant to the MOS-SFS, but nevertheless, I too used quickformat when installing my Peg2
    Christian Langeland
    DozerN on EFNet and ArcNet
  • »21.04.04 - 06:50
    Wishmaster
    Posts: 342 from 2003/6/29
    Not relevant to MOS.
    Pegasos PPC
  • »21.04.04 - 07:50
