MorphOS videos in the net !
    Estrayk
    Posts: 142 from 2003/12/30
    Config: PegasosII G4/1000, 256MB DDR400, VooDoo 3000 AGP
  • »16.04.04 - 12:24
    jcmarcos
    Posts: 1178 from 2003/3/13
    Way cool Estrayk!!!
    I have a problem, tho: My Windows Media Player 9 doesn't recognize the codec used. Any hint?
  • »16.04.04 - 12:39
    Posts: 34 from 2004/4/8
    hint : never use Windows ;) sorry...
  • »16.04.04 - 12:41
    bbrv
    Posts: 750 from 2003/2/14
    NICE!
    R&B
  • »16.04.04 - 12:41
    Spidey
    Posts: 568 from 2003/2/24
    Hi Estrayk,
    Nice! :-D
    Plays nicely with MPlayer and Frogger, although with Frogger the window is a bit small. I have to drag it to make it more squarish :-)
    Bye,
    Spidey
  • »16.04.04 - 13:42
    Estrayk
    The videos are MPEG2. So, you need Mplayer on MorphOS or PowerDVD in Windows or VLC in Macintosh for see them.
    Anyway, you also can see them in windows with wmp if you have any mpeg2 codec installed.
    Install this codecpack for windows and thats all.
    ftp://ftp.isu.edu.tw/pub/Windows/Edskes/k/klcodec225f.exe
  • »16.04.04 - 13:45
    Estrayk
  • »16.04.04 - 13:53
    liquidbit
    Posts: 407 from 2003/10/12
    Service Temporarily Unavailable...
    Targhan do something here ..:-(
  • »16.04.04 - 14:12
    DethKnight
    Posts: 139 from 2003/6/24
    I view them with Xine-DVD under slackware9.1 just fine.
    This is the best form of peg advertising I have seen yet.
    Either my xine playback is a bit fast, or the "boot-gui" sequence is stunningly swift
    I am ; therefore you are
  • »16.04.04 - 17:41
    Estrayk
  • »16.04.04 - 21:56
    brotheris
    Posts: 142 from 2003/2/24
    Nice videos, would be nicer to see some bigger usage of some programs. In the end we'll need compiled these videos into bigger promotional one.
    Home sweet home is Pegasos User Group Lithuania
  • »16.04.04 - 22:38
    Estrayk
  • »17.04.04 - 15:04
    hiTCH-HiKER
    Posts: 169 from 2003/12/31
    nice Videos, how did you make them?
    It would ofcourse be cool to have some better quality videos in DivX
    Format... if you need some webspace for high quality videos, just
    contact me!
  • »17.04.04 - 19:32
    Estrayk
  • »17.04.04 - 22:36
    DrZarkov
    Posts: 142 from 2004/3/21
    but for example I dont think that Apple people likes see how a Pegasos can runs MacOSX in a peggy without problems.
    We had this problem before with Fusion, Shapeshifter, Basilisk, etc, now it is much easier: MacOS X is sold separate from a Macintosh. You do not need a Rom-File. I don't know american laws, but in Europe they can't forbid you to use it on any computer. They can forbid to copy it, to spread it, and of course you will not get any support if you use it on another Computer but those who are listed in the readme of MacOS X. It's different of course if you take the MacOSX CDs from another Computer and install that on your Pegasos. But nobody can forbid it if I go to a Mac-Shop, buy MacOS X and install it on your Pegasos. And that is exactly what I'm going to do. Steve Jobs may know it! :-) Who cares if they like it, they have to accept! The law is with us.
  • »18.04.04 - 03:57
