How to dump DVD Video to HD?
    Donar
    Posts: 142 from 2003/12/27
    As the Subject says: Is there a way to dump DVD Video
    unencrypted to HD on a Pegasos?
  • »15.04.04 - 17:38
    td741
    Posts: 224 from 2003/4/2
    If you can watch a DVD with mplayer, then you can dump it with mencoder. ;) Right now I'm using mencoder to dump my Red Dwarf DVD's to DivX so I can watch them on my PocketPC during my commute to/from the office. ;)
    Steph
  • »15.04.04 - 17:44
    Wishmaster
    Posts: 342 from 2003/6/29
    What an irritating question.
    If it's unencrypted, simply copy it from Ambient or with a Filemanager.
    Pegasos PPC
  • »15.04.04 - 20:51
    Donar
    @Wishmaster
    THE DVD is ENCRYPTED. I want the VOB's on my Harddisk
    UNENCRYPTED for further processing later.
    MEncoder seems a usable way. I found a copy switch.
    Have to try it out, but had no luck with the right
    CLI options so far. I want the (complete) VOB's on HD
    Video+Audio. Have to go to Work now.
    Bye
  • »16.04.04 - 01:38
    Frostwork
    Posts: 302 from 2003/4/18
    Hi!
    There are various mighty linux proggies for
    s.th. like that: vobcopy, DVD:Rip, transcode (?)
    bye
    frostwork
  • »16.04.04 - 08:31
    td741
    If you want the VOB files, then I'm not sure if Mencoder will output them.
    Umm... You might be able to use the "copy" option for audio and video (not at home can't check). I'm unsure if the output will be an unencrypted though?
    Do you just want the highest quality output?
    Steph
  • »16.04.04 - 12:08
