Posts: 331 from 2003/5/12
OK, I've got a bit further with this.
The filesystem and identifier entries were fine.
Both linux & swap partition were on a separate HD
from the MOS boot partition, so I had to type:
"idec=ide-scsi", instead of "hdc=ide-scsi".
Also, "ls /cd", gives the following:
3929008 INSTALL.;1
5682 LINUX_ON.;1
645458195 PEGASOS.;1
1463142 PEGXLIN.;1
10148 README.;1
Which meant the full command was:
"boot /pci/cd install.;1 video=tdfx idec=ide-scsi"
I then get to initalize my linux & swap partitions,
which are /dev/hdc3 and /dev/hdc4, respectively.
After that, "install base system" gives:
"CD - file not found".
Manually entering dir. /dev/sr0 or /dev/hdc still gives file not
found.
Any ideas?
I feel like I'm almost there.
Robert.
