PegXlin
  • Lee
    Lee
    Posts: 70 from 2003/4/9
    i have here some problem to install pegxlin.
    After the comand "hdinstall" and some seconds later there is the install stop and
    this message is to read.
    "CP: read: input/output error"
    Any idear? The CD is okay.
  • »11.04.04 - 13:27
    gunne
    Posts: 441 from 2003/2/25
    Hi Lee
    Go for the real installer instead, which you can find here;
    Debian sarge/testing installer
    It works very good, and give you the opportunity to install a complete system at once.
    Just boot it up in ordinary way. The netinstaller is aimed for doing a netinstall, and you need to be connected to the net for using it.
    Gunne
    Best wishes, Gunne
  • »11.04.04 - 18:24
  • Lee
    Lee
    Thanks gunne,
    i will try it out ...
  • »11.04.04 - 19:50
    gunne
    Hi
    If you go for the netinstaller just boot;
    > boot cd install/powerpc/vmlinuz-chrp.initrd
    and follow the installer.
    Gunne
    Best wishes, Gunne
  • »12.04.04 - 11:04
