OWB issue
    Doffo
    Posts: 508 from 2010/10/14
    igracki wrote:
    Doffo wrote:
    is it possible to have it automatically skip the prompt for the captions, and have it automatically do the 720p format without prompting it every time?
    To skip prompt for captions, you have to set the captions to "0" in yt.cfg
    Autoplaying a predefined format isn't currently supported.
    Appreciated, I did have it at least skip the captioning. :) All is well, I dont mind selecting between 720p and the other. a 720p video takes up half the cpu usage on this quad g5. :)
    YUUUP!
  • »08.03.20 - 21:40
