Posts: 1289 from 2003/2/25
{from #morphzone}[16:26:49] <Rabel1> Hi All!
[16:27:17] <Rabel1> Quick question: Does Quake I work on PPC in PPC mode? Do I have to have a Voodoo card for it to work? Thanks.
[16:28:26] <Rabel1> Guess no one is here. :-<
1st: Download
Quake for PUP archive from aminet
2nd: extract and install it (copy drawer to your HD), add your pc files to "ID1" directory
3rd: Download
QuakeMOS4th: extract it with gzip or XAD/Voodoo-X and copy the binary to your Quake directory
5th: open information window of QuakeGUI (AFAIR it's part of QuakePUP archive) and set QUAKENAME tooltype to "quakeMOS".
QUAKENAME=quakeMOS
to use the full MOS/PowerPC native Quake1 version.
6th: start the game, it should work now w/o problems and w/o voodoo graphic card. You also could try to install it without QuakePUP, but then you need to fiddle around with many commandline options.
I hope this helps. And next time don't leave the channel that fast.
regards,
tokai
