YAM vs SimpleMail
    muckboy
    Posts: 47 from 2004/1/15
    Now that both YAM and SimpleMail exists natively for MOS, which one should I go for? Anybody here tried out both?
    PegasosII/G4@1GHz | 512MB PC2100 ECC/REG | Radeon9200/128MB | Seagate Barracuda 160GB@7200RPM
  • »08.02.04 - 12:01
    Robin
    Posts: 741 from 2003/2/24
    They're both doing the job.
    So it's up to you to see which one
    'feels better' ;-)
  • »08.02.04 - 12:31
    Posts: 154 from 2003/4/22
    Hi !
    I personnaly prefer SimpleMail. It's multihtreaded, have nice feature,
    and "almost" stable. it's very promissing.
    bye
    MorphOS Rulez !
  • »08.02.04 - 12:40
    porneL
    Posts: 49 from 2003/7/16
    simplemail.
    better handles attachments and does not lock-up while getting mail.
    this text is here to confuse you
  • »08.02.04 - 13:30
    Robin
    Yam is quite stable with disabled trance ...
    (Only locks up when you open/close a window
    or quit while it tries to connect to a server.)
  • »08.02.04 - 13:39
    docgeddy
    Posts: 37 from 2003/7/31
    depends on your taste, both are very good. On the first view both are very similar.
    DocGeddy
    Member of Butterfly Army
  • »08.02.04 - 14:21
    hooligan
    Posts: 1948 from 2003/2/23
    I have no idea what lockups of Yam you are talking about. Yam hasn't crashed even ONE time and it's been my mailer since the day I got Pegasos.
  • »08.02.04 - 14:44
    muckboy
    Thanks for the answers. I have used YAM earlier on my A4000, and recall that it went non-responsive while connecting/transfering mails to/from the mailserver. Multithreading is nice, I'll give SimpleMail a shot :-)
  • »08.02.04 - 15:04
    merko
    Posts: 328 from 2003/5/19
    I've been using YAM for many years, here are my impressions after
    testing Simplemail fairly briefly:
    Simplemail vs YAM:
    + Seems more stable, fast and generally well done
    + Does almost everything like YAM, except some small improvements
    + Supports IMAP4 as well as pop3
    - When replying to mails, cited text is unreadable white/yellow (can't
    be changed)
    - When displaying mails, it doesn't support a textured background ;-)
    So my conclusion is to wait until the reply colour problem has been
    adressed. If you're happy with white/yellow text, it seems fine
    though.
  • »08.02.04 - 15:10
