Correct Installation of AMIGAGUIDE in MOS
    Coder
    Posts: 296 from 2003/3/5
    It works. It was the reboot. I did some rebooting yesterday but I was not sure if I checked it again. And before going back I posted here. The thing that did not make it work at first was a amigaguide.datatype in the devs part were it should have been amigaguide. But the FAQ is showing it correctly now. I only checked it with one file but it worked. And I am sure the rest does too.
    I said it before and I will again, things that work right away are not fun. It has to drive you insane and when it works it makes you feel all the better.
    Coder
  • »06.02.04 - 12:23
    Spidey
    Posts: 568 from 2003/2/24
    Congratulations with an AmigaGuide-file recognizable MorphOS Coder :-D
    Spidey
  • »06.02.04 - 14:10
