How unpack *.tar.bz2
    Posts: 125 from 2003/9/8
    Hi, I have maybe stupid question, but how can I unpack *.tar.bz2 files? I didnt find any unpacker (untar, bzip2, untgz, ... nothing didnt unpack it).
    JACK - 3D gfx artist
    Config: Pegasos 2 G3/600 MHz, 256 MB SDRAM (Kingmax), ATI Radeon 9200 Pro 128MB, 120 GB HDD
    My new web: http://jack-3d.wz.cz
  • »30.01.04 - 06:51
    mahen
    Posts: 118 from 2003/2/24
    You need to first use bzip2 and then untar :)
    xmpp:mahen on jabber.fr
  • »30.01.04 - 06:57
    Posts: 90 from 2003/4/13
    <but how can I unpack *.tar.bz2 files?>
    tar.gz : tar zxvf this_is_a.tar.gz
    tar.bz2 : tar yxvf this_is_a.tar.bz2 or tar jxvf this_is_a.tar.bz2
    You can safely omit the v, it's only there to show the files scrolling over your screen while the archive is untarred. To handle .bz2 archives, you must have bzip2 installed. However, on a regular Linux or BSD-box, it is installed by default nowadays.
    regs
    hgm
    lots of examples ....;-)
  • »30.01.04 - 06:58
    OK, I have bzip2 installed, I will try it. Thank you very much :o)
  • »30.01.04 - 07:07
    And one thing in addition: My question was written in 9:51 and solved in 10 minutes. COOL!
  • »30.01.04 - 07:10
    Golem
    Posts: 766 from 2003/2/28
    @lowietje1
    The version of tar included in the MOS SDK doesn't have support for bzip2 (the j option), but you can get around that using pipes.
    Example:
    bzip2 -d -c archive.tar.bz2 | tar -xv
  • »30.01.04 - 08:23
    <(the j option)>
    Thx , I just cut and paste a linux-question from the 'net'
    My intention was not to be 'that' accurate , but just give a lead. :-) Nevertheless thx anyway Golem:-)
    regs
    hgm
  • »30.01.04 - 09:52
    Wishmaster
    Posts: 342 from 2003/6/29
    You can do it like this:
    tar --use-compress-program=bzip2 -xf file.tar.bz2
    Pegasos PPC
  • »30.01.04 - 14:27
