Viewing adf files
    Coder
    Posts: 296 from 2003/3/5
    I wonder if there are any programs that let you view adf files. A sort of a filemanager like program. Maybe there is a simple program that let you mount adf files. That way you can view the contens of the adf file.
    Coder
  • »26.01.04 - 06:17
    Jupp3
    Posts: 1193 from 2003/2/24
    You can "unarchive" contents of AmigaDOS-formatted ADF's using Voodoo-X available at Aminet.
  • »26.01.04 - 06:40
