MOS PUP and kickstart
    aPEX
    Posts: 33 from 2007/5/22
    Hello,
    any idea why I am getting just a black screen on booting if I try to use a kickstart? I tried the one that I grab with grabkick from my A4000 and I tried one that I got from an A4000T. MOS is running and booting fine, but only if I use no kickstart and the fakesomething... :)
  • »04.11.07 - 14:40
    CLS2086
    Posts: 168 from 2005/8/25
    True A4000T got kick 40.7 and scsi integrated, A4000D doesn't have scsi and got a different kickstart 40.6x
    The lastest release of MOS PuP is optimised for A4000T !
    For A4000D, you'll need to do the tricks explaned in the ISO
    Keep the Faith !
    VG 5000/A1000/500/500+/600/2000/1200PPC-GREX/1200PPC-ATEO/1200+1230-IVFPUSCSI/CD32/Pegasos 1 April1 G3/Pegasos 2 G4/ Ahtlon/K6-3/various funny machines too  :-)
  • »04.11.07 - 14:51
    aPEX
    Which tricks? And yes I made also test using my original kickstart 40.068 form the A4000 Desktop.
    I just read again the hints in the manual, but I can not find anything about using a kickstart.
    PLZ help, I want to get MOS running befor something other will be release. ;)
  • »05.11.07 - 05:40
    aPEX
    Very sad that noone will or can help. :-(
  • »08.11.07 - 05:18
    Sir_Lucas
    Posts: 112 from 2006/4/23
    Why do you need a kickstart? Is really so important to you?
  • »09.11.07 - 08:05
    aPEX
    I think it is important, because I can use my diskdrive and paula... but I want to understand why it is working on an A4000T but not on an A4000D...
    And maybe the norway.device will work better with kickstart? Just an idea...
    I used so much time to find the SFS problem and now I can still not use MOS because I have no network connection. I described the problem in the norway thread. I send an email to Chris, but it seems that noone can help. :cry:
  • »09.11.07 - 08:36
    Sir_Lucas
    Hmm, I believe I can help you with paula and disk drive.
    Download these files and put in you boot/external modules catalogue, reset the Amiga and after that you should hear the clicking ;)
    http://skolman-mws.w.interia.pl/mos/extmodules.lha
    To check paula simply download this player ;)
    http://aminet.net/search?query=Prayer2
    As for Internet and USB problem I think that Platon is the only person who can help you.
    Don't forget to post whether it's working or not ;)
    [ Edited by Sir_Lucas on 2007/11/9 17:18 ]
  • »09.11.07 - 15:18
